yiuibae
- Sep 16, 2016
Sub bass and hard (or solid) mid + high
This is my impression so far after one day of listening.
When you listen to receivers for the first time, you find that it is different from the previous one and try to understand what it presents and appreciate this. It's not common that you like new receiver from the very first moment, but N3AP did. I was hooked by its sub bass and still existent mid and high, not just me even my wife told me that she likes this receiver, she usually doesn't care about the sound quality or even thinks that most of receivers are same
Now, what's not good.
I don't think that mid and high are mellow, it is a bit hard, solid, or harsh depends on your expectation. But, this helps mid and high to survive from such a dominant sub bass.
Weak upper bass? I cannot hear much upper bass compare with other receivers. But again, the sound will be too congested if there is a strong upper bass as well.
In summary, the sound is quite different from usual V shape receivers, of course much different from flat or analytical ones, and I find it unique and amusing.
