Sony XBA-N3AP and XBA-N1AP — Impressions thread
- Thread starter Ralphee
Intensecure
Thank you.
So any generic MMCX will work then?
Plenty of options..
Plenty of options..
Wiz33
- Feb 6, 2015
- Messages
- 513
- Reaction score
- 185
Yes.Thank you.
Plenty of options..![]()
Intensecure
Thanks for the heads up.
Not really an "upgrade" more a side grade, but I wanted a cable without mic because I work out and worry sweat getting into the mic housing.
So for a small cost: (and they feel pretty good.
Trebor1966
- Jul 4, 2012
- Messages
- 274
- Reaction score
- 136
what cable did you choose?
Intensecure
Just an eBay cheapie, Earmax brand SPC for USD20 shipped.what cable did you choose?
But the quality is surprisingly good, cable sheathing is too stiff, which is a shame, but the construction details are good. - very positive, solid connectors, everything looks better than the price would suggest. And it sounds awesome!
Although it doesn't quite match my needs, because it is a bit too stiff for exercising, I am very satisfied with it, it looks good, sounds good, and it's made pretty well. My only concern is, seeing how nice it is, the temptation to try something more...Hmm, premium just for the heck of it!
Trebor1966
- Jul 4, 2012
- Messages
- 274
- Reaction score
- 136
Thank you - can you post an ebay link?
Intensecure
Not sure of the rules regarding links to sellers?
But try http://www.ebay.com/usr/wang_yifei
Fast delivery, less than 2 weeks.
As stated, cable is stiff, microphonics are not brilliant, but connections are solid, has got memory wire in the last 80mm or so (I didn't notice that when I bought it
sound is either unaffected or even better (beware placebo effect heh) but yeah I'm happy with mine.
gerelmx1986
OK, embarrassing question time...
Since I have no previous experience with XBA detachable cable models, is the Sony MMCX compatible with standard MMCX or do they use a different system? I have seen cables advertising "locking Sony MMCX" connections, and others claiming that MMCX generic will fit. And did they change between series, H to A/N?
Any guidance appreciated.
Sincé the XBA-H series it uses standard MMCX, I used XBA-H3, XBA-A3 and now i have XBA-Z5
oHellJungo
How does N1AP sound to Doom Metal, Power Metal, Symphonic Metal, Gothic Metal and Hard Rock? I'm the owner of Audiosense AS20 and used to have YAMAHA EPH-50, Denon AH-D1100 and Sennheiser HD 518. As you can see, my taste is quite bass forwarded, but also care for details, clarity and mid-treble range. However, I don't prefer bright sound as my main taste in music isn't bright.
milkdudd
- Jan 3, 2017
- Messages
- 33
- Reaction score
- 12
After reading a couple of dozen posts, it seems the N3 is said to have a pretty flat frequency response. Does anyone have a first-hand comparison to the MDR - 7550 which is also said to be pretty flat. If they're close, the 7550's can be had for about two hundred and thirty bucks right now. If the N3 could be had for the same price it would be a slam dunk I think. But there seems to be a couple hundred difference in price in the US. Any opinions on this?
Wiz33
- Feb 6, 2015
- Messages
- 513
- Reaction score
- 185
2 different type of technology. The 7550 is dynamic driver while the XBA-N3 is BA high and dynamic mid/bass, even when both have fairly flat curve, they will have different tonal quality. It's pretty much a personal preference.
Best price to get the N3 from a reputable vendor is probably through Accessoryjack ($280). Seems price on the N3 went up in the last few months as I got mine for 26500 yen in Tokyo back in Jan and the cheapest I can find on kakaku is 31300 yen now and you still have to pay for shipping and handling from a buying service like Buyee.
Trebor1966
- Jul 4, 2012
- Messages
- 274
- Reaction score
- 136
XBA-N3 is dynamic low/mid and the BA is only for the highs - sony changed there hybrid design
milkdudd
- Jan 3, 2017
- Messages
- 33
- Reaction score
- 12
Appreciate the opinions of you guys. Actually right now I have the xba-A3 with the Sony accessory cable using with a chord Mojo. Have to say I'm absolutely thrilled with the sound I'm getting. I just think I would like to have a second set in case something happens to this one. In case it breaks or gets lost or something. Guess I'm just looking for an excuse to buy yet another set of headphones. Like everyone else, I don't need much of an excuse to buy something new. I thought about the 7550 because at least it's something different technology-wise than what I have now. Not sure how different the N3 is from what I already have.
Wiz33
- Feb 6, 2015
- Messages
- 513
- Reaction score
- 185
If you already have the A3 (I do too), think of the N3 as a more compact little brother. Although the A3 is superior to the N3 in every way (but not by much), the N3 is more comfortable/compact to carry around.
