evilking
CAUTION: INCOMPLETE TRADES.
- Dec 7, 2005
How about the isolation after you used them in various environments ? There is some vent hole on the H1 ? If yes can you put later a picture where the vent is visible.
Isolation is very good, on par with most BA IEMs and the Atrios. I commute by multiple trains and have no issues.
I cannot see a vent hole.
could you compare H1 to a former XBA iem? best would be the xba 3... I am curious about the bass, if it gets bloated due to the dynamic driver
I can barely remember the XBA-3, so take this with a grain of salt. The XBA-3 was very much "BA" quality bass, better than all single/duals and on par with bass tuned triple driver IEMs. There was no comparison to dynamic driver bass, little rumble, deep but not sub-bass deep, if you know what I mean. The XBA-H1 is very much dynamic driver bass, so is an order of magnitude more bassy than the XBA-3. It depends which type you prefer.
Hope this helps.
Thanks
EK
