amrbadrawy
- Jun 20, 2015
So you say that the AP version may be less louder than the non AP version?
The A2 comes with two interchangeable cables and one of those cables has a one-button-mic-remote attached.
The A1 comes with a pre-attached, non-removable cable, either with or without mic (A1AP vs A1).
I want to make it clear that if I had to choose only one of these IEMs I would always pick the A2. Sony does this rich, detailed-yet-energetic, musical type of sound very well, and I prefer to put my money fully invested to get the better performer in that sense. Therefore the A2. The A1 as a more laid-back performer, which has too much competition in its range and signature, and doesn't deliver the "Sony punch" as well as the A2 does.
I haven't tried the A3 or Z5, mainly because I already have the H3, and, aside from sound similarities and the reality of diminishing returns, I'm also not the biggest fan of the fit and comfort; I find the behind-ear deployment mechanism very clumsy and constricting.
I like to point out a mistake on the information posted.
AP mean iphone/android compatible
VP mean android compatible
IP mean iphone compatible
That being said, I think only the XBA 1, 2, 3, 4, XBA 10, 20, 30 and 40 states this, from the H and A series they only have the AP version, which works with android and iphone.
I would like to point out that there may be a difference in a AP version vs non AP version, I have tested this on the XBA 1,2, 3 and 4 non mic version seems a little louder, this can also be the same with the AP, version as the XBA was tested with the IP, VP and non mic version.
So you mean that the A1AP is flat on the bass side compared to even the A2 which is much less bassy than the A3 i own?
I own the XBA A3, its awesome in every aspect except it's not comfortable at all and of course its never suitable for any outdoor activity even just a slow mellow jogging, so i intend to buy the A1AP, if you tried both of them what do you think, is the sound signature totally different "Considering that its not a Hi.Res certified should i better go with A2"
I'm considering Fiio FH1 (thanks for your YouTube video). Are they durable? There're some complaints in the relevant Fiio thread and other sites. Another option I was considering is Sony XBA-A1, their frequence response is pretty similar to A2 and before I had cheap Sony XB30 which last more than 3 years without any problems. So I'm torn betwen better sound and dubious build quality or better build quality with supressed trebleI tried maybe 200 pair that day in the vid and the Beoplay .......never thought I'd rec those but they had decent unintrusive low end and were really clear with no harshness up top. Can't recall price.
The combo for non scooped mid and good low and highs is hard to find and seem to need a Dynamic and BA/BA's to my ear but the Beoplay are 1 driver that were impressive
The A1 and A2
XBA-A2
- High-Resolution Audio HD Hybrid 3-way driver system
- Linear drive Balanced Armature driver
- HD super tweeter
- 12mm Liquid Crystal Polymer diaphragm dynamic driver
- Enjoy radiant highs and deep bass
General
Type Closed Driver Unit Hybrid 3-way System: 12mm Dynamic + 2 X Balanced Armature Diaphragm Liquid Crystal Polymer Frequency Response 4 - 40,000Hz Sensitivity 108 dB/mW Impedance (at 1 kHz) 32 Ω Cable 1.2m detachable Silver-coated OFC Litz Wire Y-Type cable; 1.2m detachable Silver-coated OFC Litz cable with in-line remote and mic Plug Gold-plated L-shaped Stereo Mini; Four-Conductor Gold-plated L-shaped Stereo Mini Approx. Weight(excl. cable) 9g Supplied Accessories Carrying Case, Foamed Silicone Earbuds (S / M / L each 2), Hybrid Silicone Rubber Earbuds (SS/S/M/L each 2), Clip Cable Adjuster
Microphone
Unit/Type Electret condenser Directivity Omni directional Open circuit voltage level -40dB(0db=1V/Pa) Effective Frequency of Microphone 20Hz-20,000Hz
XBA-A1AP
- Hybrid 2-way driver system
- 9mm dynamic driver
- Hands-free calls with in-line remote and microphone
- Enjoy clear, smooth vocals and dynamic bass
General
Type Closed Driver Unit Hybrid 2-way System: (9mm dynamic + Balanced Armature) Diaphragm Liquid Crystal Polymer Frequency Response 5 - 25,000Hz Sensitivity 107 dB/mW Impedance (at 1 kHz) 24 Ω Cable 1.2m Silver-coated OFC Litz Wire Y-Type cable with In-line Remote and Mic Plug Four-Conductor Gold-plated L-shaped Stereo Mini Approx. Weight(excl. cable) 7g Supplied Accessories Carrying Pouch, Foamed Silicone Earbuds (S / M / L each 2), Hybrid Silicone Rubber Earbuds (SS/S/M/L each 2), Clip, Cable Adjuster
Microphone
Source: Sony Singapore, Sony China, Sopp
