As I understand it the PHA-3 does not invert the analog signal as would be needed for balanced operation with an unbalanced input signal. It uses the balanced output of the DAC chip to offer balanced output from its digital inputs though.
Thanks!
In fact I have only 2 headphones that are cabled for symmetrical use (Z7 and a modified old T1), so I did that more out of curiosity and to have it available for meets etc.
Loving the versatility of this little beast!
Plug in a Z7, it's smooth and easy going; plug in something more revealing like a Fidelio S2 it becomes a critical bitch and trash half of my record collection.
It will not charge during playback. That's the biggest flaw of Sony daps however, but you can now buy a digital out charging dock for around $150.00 from Japan.
Wow that's dumb.. so that means if I rubber band both units together to use around the house, when it's time to charge them I have to hook up two cables one to each unit from the mains?
Yes. That's why all of us hate WMport. This is less of an issue for the ZX2 given its amazing life. C'mon now dude...your DD9 didn't last more than 4-5 hours...if that all. The biggest shortcoming on the PHA-3 is definitely the battery life. Due to EU regs, the EU PHA-3 runs on main voltage only hence the name PHA-3AC.
It's not even the battery life that I'm concerned with (I don't listen for more than an hour at a time anyway), but that constant swapping of cable heads on the WMport might wear it out? idk
Guys, I need some help. If I have a balanced 3.5mm trrs plug used for the zx2,will it still work with the pha 3? Or am I going to get sound out of 1 channel?
I think the single-ended jack is just that: single ended. Using a balanced headphone with a TRRS connector will just give you sound on one channel (OK, there might even be a position where both channels work, but still single ended).
3.5mm TRRS plugs have the two grounds adjacent. If you plug them into a single-ended headphone out that doesn't support mic/controls, the two grounds will both connect to the jack's ground. If the device supports controls (like an iDevice or android phone) then one pole will be for the controls and you will only get one channel. I have tried many DAPs and amps that don't support controls and they usually work with balanced 3.5mm TRRS headphones. This is not true for the AK 2.5mm TRRS because it orders the signals differently.
