drbluenewmexico
- Dec 21, 2009
YesDo you mean the micro-usb port of pha-3 ?
No, that’s for charging. I’m referring to what I guess is the “Walkman” port.Do you mean the micro-usb port of pha-3 ?
Yes that is what I meant and I'm using the walkman port to connect Sony NW-A45 to PHA3 via Fiio L27 cable (wmport to micro-usb)No, that’s for charging. I’m referring to what I guess is the “Walkman” port.
Sorry, I’m not following how this is relevant to my question. Not trying to be snarky. I’m just not sure where you’re going. My question is specifically about getting hi res audio from the iPhone to the PHA-3.Yes that is what I meant and I'm using the walkman port to connect Sony NW-A45 to PHA3 via Fiio L27 cable (wmport to micro-usb)
Sorry, maybe it's a misunderstanding, please refer to the below diagramSorry, I’m not following how this is relevant to my question. Not trying to be snarky. I’m just not sure where you’re going. My question is specifically about getting hi res audio from the iPhone to the PHA-3.
I apologize but you’re losing me.Sorry, maybe it's a misunderstanding, please refer to the below diagram
As you can see the iphone is connected to usb-a so I was curious if you can also get connection from iphone using micro-usb ie "walkman" port.
Anyone else seeing this issue?All, I have the PHA-3. Have had it for a couple of years. I use the Apple camera adapter to get high res from my iPhone. I have to use the Sony cable supplied with the PHA-3 (don’t recall the special port name but it has two holes that the cable plugs into). Then I need an adapter cable between that cable and the Apple camera adapter to complete the connection.
It works, but the cables are VERY sensitive to even the tiniest movement. If I move the camera adapter even slightly, I lose the connection from my phone to the PHA-3. I’ve tried two different camera adapter cables at this point. It seems like there’s something very twitchy about the connection and I’m stumped. Anyone else have this issue?
I own pha-3 since 2015 and I don’t recall having this issue, I use it very rarely though nowadays.Anyone else seeing this issue?
Why do u need a camera adapter when any Apple charging cable will work directly into the iPad port on the PHA-3?I own pha-3 since 2015 and I don’t recall having this issue, I use it very rarely though nowadays.
But when I do I still enjoy it a lot - awesome combo with XBA-Z5
I just decided to pull it out again and everything seems to work just fine - camera adaptor into micro usb cable into Walkman/Xperia port.
No issues when moving cables/device/adaptor.
I’m pretty sure one doesn’t get hi-res using standard lighting to usb cable. PHA-3 confirms this through its light indicator status.Why do u need a camera adapter when any Apple charging cable will work directly into the iPad port on the PHA-3?
