Subhakar
- Nov 26, 2015
The new Sony Walkman:
An interesting point from the engineer interviews I haven't seen noted here yet is that the lower quality capacitors in the 1A are only in the single ended circuit. The capacitors in the balanced signal path are the same audiophile ones on both models, so if you don't need single ended, the 1A had one less disadvantage.
Are you guys planning on recabling your headphones because of the 4.4mm jack?
Buttons? What?
I don't actually have a balanced cable for full-sized headphones, might actually get one now. Might need to reterminate an IEM cable or two.
Oh, I would be very happy. However, I need to confirm this before anything else ? Not sure if this is the case. I do know that the Z sounds much different than A when used in Balanced connection 4.4mm on Z1R.
Too many.
For your reference, this was stated here by one of the engineers that worked on electrical design. The relevant text is just above the photos of the two circuit boards. He states:
"Actually the number of these (polymer) capacitors slightly differs between the WM1Z and WM1A. The circuit board's B face (balanced) has the same number, but the A face (unbalanced) on the WM1A has some OS-CON as well."
Of course the caps aren't the only difference, and everything I've heard so far also indicates the two players sound pretty different.
What do you listen to that you can't find via streaming services?
stuff
Japanese songs.
Either way if the songs I want to listen to is on streaming I wouldn't use it, my data allowance on mobile is too little to let me burn it to listen to music - something that a lot of people who advocate streaming don't seem to understand either. I'm not ready to upgrade a data plan just to listen to music - that's insane. But I know for a fact that carriers often uses that as a baiting tactic to sell more expensive data plans.
Streaming is merely one option - it's not the definite future.
