SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
blazinblazin
- Nov 19, 2015
How do you like the Leonidas? Is it bright?
I need some time to run the cable before more comments.
The first time i put on was very bright, now better settled down a bit.
soundkist
Definitive upgrade from the Sony Kimber cable, at least initially? I have the exact same setup (minus the Leo--have the kimber instead), but I'm not sure I'm really in love with the sound vs what I was hearing on SE. I don't know whether to attribute this to the cable, that I only have ~100 hours on the balanced, or perhaps something else.
proedros
anybody here owning both WM1A and IDSD Micro Black Label ?
TenderTendon
- Sep 15, 2016
Does anyone know if the RMT-NWS20 remote control can be paired with more than one player? I know the NW-WM1A/Z can be paired with more than one remote, but not sure about the other way around. If the remote can be paired with more than one player, what are the instructions? The user's guide for the remote contains no English language at all. Thanks.
gerelmx1986
you mean opérate two players at the same time with it? if that's the case i think is not posible but to pair it with other player maybe need only to store the control address on the corresponding player
TenderTendon
- Sep 15, 2016
No, not at the same time. I would just like to use one remote with whichever player I decide to use. Only one player would be turned on or in range at a time. Also, if it is not possible to pair the remote with more than one device, what is the procedure for un-pairing, so it can be paired with a different device? When the remote was brand new, it went into pairing mode as soon as I hit any button, so the users guide wasn't needed for that.
Lavakugel
- Dec 9, 2013
Current Setup
Looks nice. How is this setup sounding with andromedas? Are they comfortable to wear?
Lavakugel
- Dec 9, 2013
Is the firmware update improving speed scrolling and boot time?
jamato8
Boot time still takes a while. Longer than I would have expected but nothing is perfect. Scrolling seems to be faster.
Lavakugel
- Dec 9, 2013
Everything over 30 sec is too long in our fast moving world where nobody has time to wait anymore
jamato8
Right. I just do something while it is booting. Tiny lag, well go back to a portable CD player and find out what lag is all about. :^) Oh, and a stack if you want to use an external amp, and more if you use an external dac, which I used to do.
blazinblazin
- Nov 19, 2015
Both cable sounds different.
Kimber give you the room/hall feel and more relax.
Leonidas so far is more open venue with more energy.
soundkist
Cool, thanks very kindly for the early impressions; looking forward to hearing what you think of the Leo down the road after you've had some time with it.
- Jan 1, 2014
Or just never turn it off, like many of us do. Cheers
- Status
Total: 9 (members: 0, guests: 9)
