nanaholic
- Sep 2, 2010
i did that
hold + or play on the remote and it flashes red/blue
turn on bluetooth on the 1z and scan, it just times out (and bt works as i have used it earpieces...meanwhile other devices see RMT-NWS20
and your 1z? i reset the region using the tool (figured that was how to get the eng menu)
looking for another battery, maybe it's weak
Mine is non-Japanese Asian model, so I doubt it is region locked.
Are you using the "remote control" setting on the 1Z? Audio device pairing and remote pairing is separate. Also maybe move away from possible interference from the other devices.
