MrWalkman
Do you have a list of instructions to install everything in the proper order which the end result will be the WM1Z/Z++?
Install WM1A/Z++, switch the model to 1Z, then install it again.
No chameleon 2.0 needed?Install WM1A/Z++, switch the model to 1Z, then install it again.
Hence why I corrected myself from up top. What's important for me to say, thank you for the step by step. Will see how much the volume is boosted vs the stock 1Z I have. I hope that's a good thing to compare.All the WM1A 2.0 mods have the 1Z base sound included.
The WM1A 2.0 mods are CHAMELEON, WM1A/Z+, and WM1A/Z++ and they are only made for the WM1A.
So if you want to install WM1A/Z++, you don't need to install CHAMELEON first. They are separate mods, with the same 1Z base sound. I have no clue where you got the idea that you would need to install CHAMELEON first.
Mistic Traveler can you share part of the near future with us?
A bit, yes, but the Beeping tones are too loud, and I got some distortion on songs I know wellAnyone else experience that the volume is slightly quieter with the WM1A/Z++? It’s happening to my MDR-Z1R as well
Weird. The WM1A/Z++ smoothes our everything and provided an evenness in the purity of sound coming all over. It’s super soft and gentle regardless of the music playing. Interesting.A bit, yes, but the Beeping tones are too loud, and I got some distortion on songs I know well
Curious if anyone with the 1z did try to install the new 2.0 mod out of curiosity (and/or envy)?
No distortion for me. But am I correct that the volume sounds a little quieter and gentler, just smoothes out the highs, mids, and lows to make it more cohesive and easier to listen to the ears than the stock 1Z?It cannot be installed on 1Z, but feel free to try.
I didn't encounter any distortion myself.
same signature, volume appear lower cuz of larger soundstage.No distortion for me. But am I correct that the volume sounds a little quieter and gentler, just smoothes out the highs, mids, and lows to make it more cohesive and easier to listen to the ears than the stock 1Z?
