SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
MrWalkman
Thank you so much for sharing! So these two different firmware's are completely different? Which firmware would change the sound WM1A to equal/exceed that of the WM1Z? Thanks again!
Well, it's already mentioned in the description I guess
WM1A/Z+ is intended to bring sound improvements to both 1A and 1Z, while WM1A to 1Z is just meant to give the ability to experience the stock 1Z sound on a 1A.
I also scanned them all four actually, and nothing came up.
Could you also show the name of the file, please?
Even tuning mods are known to cause false positives.
captblaze
Ravenous
- Jan 6, 2011
What would be the difference of improvement of the WM1A/Z+ vs the 1A to 1Z on a WM1A? I apologize if the question is redundant. I've tried the previous Model Switcher and I could barely notice a difference with the "WM1A to WM1Z" switch with that one.
MrWalkman
Look at this for example:
Unfortunately it is not in my control. Help yourself, or do not.
MrWalkman
This is not just a Model Switcher, it's a custom firmware.
Feel free to try it. Also, there are some posts back on the thread with impressions about it.
Ravenous
- Jan 6, 2011
You might want to disable Windows Defender while using these programs:
To turn Microsoft Defender Firewall on or off:
- Select the Start button > Settings > Update & Security > Windows Security and then Firewall & network protection. Open Windows Security settings.
- Select a network profile.
- Under Microsoft Defender Firewall, switch the setting to On. ...
- To turn it off, switch the setting to Off.
MrWalkman
It's ok to be worried, but there's absolutely nothing to worry about here.
You're all welcome to scan them with some better antivirus programs or something.
Gamerlingual
I had zero issues downloading. It works fine for me. Gotta get some burn in time on this
MrWalkman
Also tried ESET Online Scanner, and got no issues with all 4 files.
Link: https://www.eset.com/int/home/online-scanner/
Ravenous
- Jan 6, 2011
Wasn't trying to advertise for anything, was simply giving instructions on how to turn off Windows Defender, which seems to be the problem he was having with opening the files.
MrWalkman
Oh, I had no problem with that, I just had something to say I guess
Redcarmoose
Remember those times when you wanted to listen to all your favorites all over again. The times when it was so exciting you didn’t sleep. Well get ready because this is that time. Cheers!
We have so much to be grateful to MrWalkman for. He has changed our humble 1A players into the stuff of dreams.
wahdoy
I was having problems using Google Chrome browser. I used Firefox and it allowed me to download the files without any problems. I'm also running Windows 10.
captblaze
that makes sense.. i am using the new edge chromium based browser...
- Status
Total: 26 (members: 1, guests: 25)
