Ravenous
- Jan 6, 2011
It should work only for fw 3.02 sorry.
Ah. So if I update to 3.02 and install Orion 9, then downgrade, it will switch back the sound signature to default 1z?
Any official fw will do.
No, Orion9 should only work with 3.02 installed. If you revert back to 3.01 you will lose Orion9.Sorry I don't quite understand. It installs only on 3.02? Can I downgrade to 3.01 after installing the Orion 9 tuning?
And do not forget to wash your hands in between every step.if i want to switch from 1a to 1z , should i do the switch mode first , then install stock 3.02 and then any of those users FWs like Orion 9 ?
is this the correct order ?
The only possibility to match or pass the 1Z sound quality is HW mods.
I believe you have to update to 3.02 first then switch as the switch only works with 3.02. You can downgrade to 3.01 with the 1z firmware but the tuning mods only work with 3.02 as far as I know.
It’s fully guided, you press a couple of buttons from a menu, job donethanx , i am still trying the orion FWs , will probably do the 1a>1z switch sometime maybe next week
is the procedure simple/easy to do ?
Which software mod did you install?I own a 1Z and it has been OK. Only when I installed a specific software mod (all other mods sounded very very similar and meh) it blew me up with my gear.
where?Ok guys I just updated the link you should see stage 8 and 9 along with the 5
