Idk bro...I do it in my own preferences and experiences. But every bit of upgrades will contribute a lot to the WM players.
How does my WM1A do now ? I have not had wm1Z for a while. But I can tell you what it improved for me
I am gonna list out the cons or negatives of Wm1A stock
1/ Most noticeably is the emphasized on Bass and lower mid bass...but doesn’t dive deep enough into sub bass. Good extensions but blooming and hazy
2/ sound signature is more balanced than wm1Z which is a little warmer but without that bass emphasis and has great sub bass and control when compared to WM1A stock
3/ Mid is fluid but upper mid fell short on it energy, extensions and details at upper mid and lower trebles
4/ trebles is a little boosted up on upper frequencies
both #3 and #4 makes stock 1A to loose out some resolutions in mid and lower trebles. It is there but the #1 bass take over everything
Then in some bad recording, the sibilants can be harsh.
5/ soundstage: wide and expansive, Tall and vertically impressive, but cue of positioning is hazy and confusing
6/ pitch accuracy: this is the worse....the pitch accuracy is pretty much Mid-Tier level
7/ Airiness: pretty congested considering all the Negatives altogether....especially because of upper mid and lower treble fault
I wouldn’t call stock Wm1A to be in the same tier as WM1Z. That shows how much better power supply caps could improve the platform
Stock WM1A is pretty mid-tie
So, what does the modified unit sound like ?
Neutralizing the bass emphasis, bring deep sub bass and extensions, better textures.
Mids are now fully energetic and vastly improved on upper mid and lower treble details/resolutions.
trebles are now with better resolutions, extended ways better, and all together bring a great senses of airiness.
Soundstage is vastly improved into expansive and enveloping presentations with great airiness.
Fluidity and liquidity remains and improved to be a better flow between transients which brings musicality while Being “references”
I could improve the Lowpass filter, but there is no need. The WM1Z uses the same, so ATM, I enjoy it this way
Resistors could also be possible to upgrade but no need. I love MEL, and the MELF within WM1A is top on the market still
After modification: WM1A is now “Top-tier level”.
This picture will not show DC 20AWG Litz Ground connection
