Thanks, but the USB DAC is for it to function as a DAC, I want the other way around, for it to function as a digital transport and connect it to an external DAC. Is this possible?
So I did things little backwards. Got DMP-z1 but then wanted more portable so got wm1z. Which it great don’t get me wrong. But doesn’t push iems or headphone as much.
Have some chores or I’d of tested already. But curious if anyone else used their WM with pha-2a (or pha 1/2/3) to boost? Is this just dumb?
High gain IS the ticket with the IER-Z1R. Also I’m betting money your 1Z did not come with the latest firmware. While many here are really into firmware update 3.01......I found the new 3.02 update to take the 1Z to an amazing new level. Pretty much the best I’ve heard.
Is it worth it to buy it if you’re only using IEM’s? And budget ones? I have Tin Hifi T3, Tin Hifi P1 and KZ AS10. All of them with unbalanced cables.
That’s my other question, is a balanced cable a most? Or one can live with the unbalanced 3.5 port. Specially with those IEM’s, will I hear any difference?
