SONY NW-WM1Z / WM1A
Status
Not open for further replies.
Sep 27, 2018 at 1:00 PM Post #23,900 of 45,723
owned a few cable with Furutech rhodium plated plug, they are harder to solder on and go off easier than gold plated one
not only effect audio put some heat glue in the heat shrink, the local repair workshop here in HK also do
I definitely agree with this. Pentaconn is easier to work with. Cold and weak solder joints could happen more with furutech plugs if cares were not taken to details.
Sep 27, 2018 at 1:02 PM Post #23,901 of 45,723
Sep 27, 2018 at 1:20 PM Post #23,902 of 45,723
Just an FYI for those with decent soldering skills, but never soldered Litz wire before - don't try unless you have a solder pot.
Sep 27, 2018 at 1:22 PM Post #23,903 of 45,723
Lol! People with decent soldering skills can work around many things...including Litz even without a pot. You meant amateur level ? It is true though, litz is harder to work with
Sep 27, 2018 at 1:29 PM Post #23,904 of 45,723
I was being nice. :smile_phones:
Sep 27, 2018 at 1:30 PM Post #23,905 of 45,723
Sep 27, 2018 at 1:41 PM Post #23,907 of 45,723
hmmm i have been told by a friend that the international model sounds veiled as compared to the Japanese domestic sales model. Is there anyone who can verify/debunk ? Am thinking of getting it.
your friend also believes that aliens killed JFK , right ?
tell your friend to stop saying such thing , makes him look stupid
cheers
Sep 27, 2018 at 1:50 PM Post #23,908 of 45,723
Lesson. Don't skim on these components. Just go buy a couple of Pentaconn, and you can sleep easy at night.
If I am not wrong, even the 4.4mm males on the Sony cables aren't even Pentaconn.
You and I have the same guess. But I do think Sony had the deal with them so that they (and Kimber) could read and follow the design and data from Pentaconn. I think the problem with 3rd party is because they don’t know the data of the Pentaconn design parameters
So I totally agree with you, Pentaconn if you can, and Furutech if you must.
Sep 27, 2018 at 2:00 PM Post #23,910 of 45,723
I have a Bispa Duracon 4.4mm female connector for an extender, it's ok. But mainly because there are no other options available.
I have a few converter made with Bispa jack and they work extremely well imo.
Honestly, nobody would expect the Bispa plug have the same quality as Pentaconn OFC, but it only cost around 15 USD or so and it is precisly made in Japan, why not?
Upper Bispa , below Pentaconn OFC
Status
