gerelmx1986
Inside WM like 20 - 25 MB/s, on SD card reader between 50 and 80 MB/s, a SanDisk 400GBBut what speed do you get when you are transferring files?
Slow ? You guys need NVME which does 3.5Gb a second or so![]()
I have NVME in my notebook. I would love to have this speed at least in the memory inside the WM1Z, but it's just 30 mb/s. For me it's ridiculous this speed. Any microSD has better speed than this.
Good things come to those who wait LOLI have NVME in my notebook. I would love to have this speed at least in the memory inside the WM1Z, but it's just 30 mb/s. For me it's ridiculous this speed. Any microSD has better speed than this.
@bflat I load music every 3 - 6 months, hell this 400gb has plenty of space
You would need a U3 Class SD card to get similar read/write performance, however those tend to be lower capacity. Next step up would be UHS-II spec cards that use extra data lanes to transfer 200-300 MB/s but that requires your device to have those extra data lanes enabled. Highly doubtful that Sony did that for DAPs but they do have them for their digital cameras.
How much data are you reading and writing on a daily basis where speed is a factor? I know the initial loading of all you tracks takes hours, but for me its a CD or 2 per month addition.
I have 1.08TB of music512gb MicroSD is coming. If you buy DMP-Z1, you can have 1Tb external memorieswoaaa
The problem is that I have other DAPs and sometimes I need to change the microsd from one to another. Sometimes this doesn't work and I need to format and transfer again.
With my two Samsung 256 GB Evo Plus it's fine, the transfer speed is around 70 mb/s, but the Sandisk 400 GB is much slower. And 256 GB is not enough for all my music. That's all.
That's correct. Samsung is U3 class so write and read speed are similar so that is why you see 70 mb/s. Sandisk 400 GB is U1 class so write speed drops to around 40.
It's not surprising that you are unable to universally use the same SD card across different DAPs. I have not seen a consistent pattern of exFAT or FAT32 supported DAPs and these formats are not compatible with each other.
