SONY NW-WM1Z / WM1A
- Thread starter leylandi
- Status
- Not open for further replies.
ledzep
For anyone who's looking for a leather case handmade at a very reasonable price lots of custom choices too.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/332217241818
bana
- May 21, 2014
Will do,
Thanks to the member for the case!
Much mahalo's bro!
This looks like a fine case, do you have a link to purchase?
Thanks,
Hawaiibadboy
BANNED
Thanks,
It is an awesome case!
https://store.shopping.yahoo.co.jp/e-earphone/4589962102398.html
item i.d. is
CP-NWWM1LCP/B
http://www.cmpg.co.jp/musashino/nwwm1lcp/index.html
yakitoroi
- Jan 31, 2017
item i.d. is
CP-NWWM1LCP/B
Thank you for this, you Sir are my hero. I have been looking for something like this for a while to replace with the sony flip up case and I am not fan of cases that doesn't cover the screen. Thank you.
SoLame
The Sony original balanced cables that shipped with the Z5 have 2 separate (3.5mm?) L & R jacks whereas the Kimber has one 4.4mm jack. How is it possible to say that one is better than the other unless using a balanced amplifier like PHA-3.
Straight through the WM-1A the 4.4mm can be tested but not the original balanced cable supplied by Sony.
My guess is he was referring to the Sony MUC-M12NB1 as 'regular cable', not the stock balanced cable that comes with the Z5.
asquare3376
No. He specifically mentioned dual 3.5mm, so balanced stock cables which goes with PHA-3 and the likesMy guess is he was referring to the Sony MUC-M12NB1 as 'regular cable', not the stock balanced cable that comes with the Z5.
gerelmx1986
Did the experiments and WM1A and 1Z don't support Folder.jpg nor Cover.jpg (files with no cover embedded), therefore the covers must be present in every file as embedded option. My older NWZ-A818 did this, it supported external covers
flyer1
- May 18, 2009
Others have the same experience that the Sony Kimber balanced cable sounds a bit dull?
Also wasn't impressed by the build quality of the Sony Kimber Cable especially the connectors.
I just ordered the 'regular' MUC-M12NB1 in addition to use with my 1Z just to see how I like the difference between both cables.
audionewbi
- Jan 24, 2010
I find the kimber cable dull and not worth the purchase. However Sonys own cable is rather good, but bit stiff. MUC-M12NB1 gets my vote.Others have the same experience that the Sony Kimber balanced cable sounds a bit dull?
ledzep
Initially I was excited to see these Kimbers for the Sony range but after the mmcx connectors became loose on them I decided to re terminate and check out the build quality overall by opening the splitter up to check the solder joints etc not good really loose strands, solder balls and flux residue not what you'd expect from a "premium cable" but in saying that once it was cleaned up and re soldered with silver solder and a pair of eidolic premium connectors and a 100 hour burn in it wasn't that bad a cable for the price, but there are plenty of other custom built cables around that price point to consider so don't buy in haste and repent at leisure as they say. In saying that I sold my kimbers and bought a plussound tri metal from a fellow headfier and re terminated it with a furutech 4.4mm and the eidolics and it leaves the kimber for dead soundwise.
Fixxer6671
I have the limbers and they sound really good with my SE 846’s.
Fixxer6671
How is everyone charging their device?
I currently have the charge up to 90% box checked.
Do you leave the device on between uses or is everyone powering on and off?
I know this sounds basic but really want to get as much life out of the battery as possible.
Thanks
Thanks
- Status
Total: 15 (members: 1, guests: 14)
