TonyStarks
Are you able to adjust the volume output??Yeah, of course it does. Pairing perfect with my H2.
1Z is like music server now, you can only adjust volume on your dac/amp. In this case is my Hugo 2.Are you able to adjust the volume output??
I used to have the M11 Plus. The M2 is slightly taller and wider however, the ergonomics are way way better! The M11+ has some sharp edges and is designed like a brick. The M2 will definitely not fit in a shirt pocket but itll fit perfectly in trouser pocketsWow! Just caught up with this thread, a lot of posts for very few people having them in their hands
I can't ever see myself being in a position to buy a 1ZM2, but perhaps an 1AM2 at some point but it would have to be an uncapped version. I still have my 1A. I recently bought a Fiio M11 Plus for the steaming side (which I don't do much of) and use as a transport, with my 1A still being used for portable purposes. From what I can see the new models are a bit longer, but only slightly thicker. The 1A is already a bit thinks and difficult to fit in pockets (especially shirt pockets).
How do you carry your M2s around with you - or do you just plonk it on a desk / keep in your hand?
Do you think it would be worth selling my 1A and Fiio to fund the new 1AM2? Is the step up in quality significant?
Can't say for sure but it doesn't look like there's any SRC bypass happening. Bitperfect only seems possible with the Sony Music player. Sony would have to build their own SRC bypass tech for Android, and I don't believe they have. That said, as long as a music player app has its own driver, it could potentially bypass SRC on the M2 players. UAPP is a good example.Not sure if this has been discussed before, but can someone explain this diagram I found? What happens to 24bit/192kHz signal path when streaming or using other than Walkman apps? Is Android SRC being bypassed, or does it get down-sampled by Android OS and then up-sampled to 192kHz? Bit-perfect playback implies that nothing should be down/up-sampled, but it is not clear from this diagram.
Anybody has more info?
That's what I saidAnd UAPP. Only true Bit-perfect with Walkman Music app and UAPP with its own audio driver hooking into the Red path.
This is pretty much it!And UAPP. Only true Bit-perfect with Walkman Music app and UAPP with its own audio driver hooking into the Red path.
The Android will not implementing it own SRC alone, but it is also Sony and their Audio configuration policy XML. This is similar to the firmware tuning by XML in Walkman M1 (still when going over Android it does conversions as you mentioned)It's all speculation, I guess. Obviously, Android can't pass 192k, it will be down sampled, yet it says that you will get a bit perfect with Amazon HD, 192kHz. The 48k/192k selectable is your hi-res streaming switch. Then, should we assume that it will be up sampled back to 192k? My point, you can't call it bit perfect if you are down/up-sampling it.
Also, based on what I tried, UAPP doesn't do bit perfect streaming of Tidal on WM1ZM2, only up to 88.2kHz.
Yep, UAPP only 1 unfold for MQA.It's all speculation, I guess. Obviously, Android can't pass 192k, it will be down sampled, yet it says that you will get a bit perfect with Amazon HD, 192kHz. The 48k/192k selectable is your hi-res streaming switch. Then, should we assume that it will be up sampled back to 192k? My point, you can't call it bit perfect if you are down/up-sampling it.
From what I understand, Android 11+ supports two SRC resolutions: 48kHz and 192kHz. If you play files in either bitrate, they don't need to be resampled. All other files will get 'downsampled' to 44.1 or upsampled to 192, but in theory, 48 and 192 files are untouched. Hence Apple and Amazon 192 tracks playing as-is.It's all speculation, I guess. Obviously, Android can't pass 192k, it will be down sampled, yet it says that you will get a bit perfect with Amazon HD, 192kHz. The 48k/192k selectable is your hi-res streaming switch. Then, should we assume that it will be up sampled back to 192k? My point, you can't call it bit perfect if you are down/up-sampling it.
Well said ***From what I understand, Android 11+ supports two SRC resolutions: 48kHz and 192kHz. If you play files in either bitrate, they don't need to be resampled. All other files will get 'downsampled' to 44.1 or upsampled to 192, but in theory, 48 and 192 files are untouched. Hence Apple and Amazon 192 tracks playing as-is.
And it happens on the M2 as well ?Actually, other than on PC, Amazon Music still outputs from Apps at 192 irrespective of source bitrate for Android & IOS. I was surprised on the iPhone with Khadas Tea and Fiio BTR5 wired,
Well said ***
What I don’t understand is how does Walkman app extend the playtime toward 35hours where as other apps is about 18 hours ….. but coincidentally…Walkman app with all DSP on will be around 18 hours as well ? Is that correct ?
