Jan 17, 2013 at 12:38 PM Thread Starter Post #1 of 5
mulalleybs
First, I'd like to say I appreciate any and all help you guys can give.
Just got the headphones which came with no instructions, I also tried finding some online to no avail. Anyway, I plugged the headphones into my phone (Verizon Razr Maxx) and started listening to some music. I thought it sounded terrible, but then I pushed a button in the center of the smart control (the button between the + and -) and then it sounded great. Now my problem is that it only sounds good while the button is being pressed down, as soon as I take my finger off it goes back to sounding bad. If you guys could tell me what I need to do or point me in the right direction I'll be grateful.
Brett
Jan 17, 2013 at 12:54 PM Post #3 of 5
this means you have the MH1 and not the MH1C. it can be fixed by using the following adapters:
http://www.lunashops.co.uk/goods.php?id=1073
http://www.mp4nation.net/headphones-amps/headphones-earphones-1/fiio-audio-products/fiio-lu1-3-5mm-smart-adapter-cable-ofc
http://www.mp4nation.net/headphones-amps/headphones-earphones-1/fiio-audio-products/fiio-lu2-3-5mm-smart-adapter-cable-ofc
Jan 17, 2013 at 1:31 PM Post #4 of 5
I appreciate it gentlemen. I called the company I bought it from and it seems they sent a bunch of MH1s to people instead of the MH1C. So I'll just return these and buy the correct pair again. Any idea on cheapest site to get em?
Jan 17, 2013 at 1:44 PM Post #5 of 5
well i couldn't find them cheap so i bought the mh1 and will use them with the adapter
