Sony MDR-V6 vs Shure SRH440 vs Shure SRH550DJ vs Pioneer HDJ-500
Jun 29, 2013 at 8:36 PM Post #19 of 22
Well this is also a subjective question and result will vary subject to noise coming from outside but I think it will be able to block the outside noise to a good level. If you want to completely block the outside noise you need something with active noise cancellation.
Jun 30, 2013 at 5:12 AM Post #21 of 22
Sound is really subjective issue and I suggest you to try them before buying them. Also I highly suggest you to try AKG K167 as well. Then you can make a decision. Personally if I decided to buy SHR550DJ I would rather save up a bit more and buy a SHR750DJ instead.
Jun 30, 2013 at 8:10 AM Post #22 of 22
Do these have good soundstage?
Imo no closed headphones have a good soundstage. For a good soundstage you need something very open, like a Sennheiser HD598.
