pearljam50000
- Apr 7, 2013
How do they compare to AKG K550?
Yeah. That sibilance.
Okay, so after some extensive listening and a bit of comparing back and forth, this 'cotton-mod' does add a slight amount of boominess to the bass, which lessens the SQ a bit. So I guess I can confirm what third_eye said. So in spite of the added comfort the cotton-mod provides, I've removed it and will just live with a little bit of pressure on my left ear. Either way, it's not nearly as bad as all the other headphones I've tested so far I just don't like what it does to the sound signature.
And the Shure SRH1540 will probably arrive Thursday, so I'll do some testing over the weekend
could you post a pic of it please right now I have the p7 and absolutely love them, but a few days ago I tried the 7520... damn now I want them aswell, maybe when I sell my momentum
Unfortunately no, and that's why I sent it back
I tried EQing it like you guys told me to and it sounds great! However, the EQ I was using doesn't let you save custom settings and it fails to work a lot. What EQ would you recommend for use on Android?
