FunyunBreath
- Feb 5, 2009
From the way you describe the sound, it sounds just like the sound signature of the Shure SRH940 pads (which are also velour) (and not to be confused with the SRH840 pads, which are pleather).
And you also seem to have cut out the center of those pads, or did they come like that?
The Beyer pads don't have any sort of screen/mesh built into the pad. They come with circular foam inserts but they don't really fit properly on the Sony's. I've been messing around trying to find a good material to sew or glue onto the backsides of the pads.
