davidmthekidd
- Nov 14, 2015
How can I activate Google assistant with this headphones?
Press and hold the middle of the right coup with your index finger.
Has anyone had any luck getting DSEE HX to work? I can't hear any difference by having it on our off. I use the LG-G6.
The DSEE HX activates only when connecting using codecs other than LDAC with a BLUETOOTH connection, Looks like you can not turn it off.
You can indeed turn it off in the IOS App. There is a marked sound difference between on and off.
On the WH-1000XM2 yes you can, but not on the MDR-1000X as it's not compatible with the App - unless I've missed something
On another note there's a bit too much confusion in this thread as it's easy to lose track of which headphone people are talking about. Maybe the WH-1000XM2 should have it's own thread, if it doesn't already.
Sorry about that, I have edited my post to make this clear.
So, do you think it is defected is that I have don't have a good seal with the headphones. It could possibly be that my brain is kinda loose in my head.
In terms of stability sbc works perfectly, before I had the mrb 1rbt, and the sbc always jumps between tracks and another, with mdr 1000x running incredibly stable this connection, I can listen for hours without jumping in the playback. Since the LDAC sometimes runs well, even in priority mode in the sound, but anywhere with wifi signal, playback suffers from jumps, in my home is still worse, sometimes in a band gets to have more than 2 jumps during the playing of music, and sometimes interferences that get to last seconds, if I choose the effort mode in the connection improves but still yes it has some jumps between the tracks.
The problem with LDAC is not only in my mdr-1000x, but also in my SRS-XB3 sound box. In both I set to run only on SBC, until Sony actually fixes this problem with LDAC.
I believe that in the Walkman, the connection is more stable, I did not have the opportunity to test in one, but in all the Xperias I tested and using LDAC, I had the same experience of instability.
You seem to be blaming LDAC for causing slowdown of your 2.4GHz WiFi. Connectivity doesn't work that way. Have you compared your internet speeds (e.g. Speedtest) when connected to 2.4GHz vs 5GHz vs cellular? Very likely you are using slow 2.4GHz connections. Most WiFi routers default to operating on 2.4GHz (I think because 2.4GHz penetrates walls better than 5GHz). When there are many routers nearby, 2.4GHz airspace can become congested and lowers the bandwidth.whenever I'm on a 2.4GHz WiFi the internet speed decrease to almost zero or unusable depending of WiFi signal strength. And this happens every freaking time. Only way to get usable internet connection with LDAC on is either use cellular data or 5GHz WiFi connection. Very bad design defect IMO
I've been using the MDR-1000X's with Xperia XZs and haven't had any problems with the LDAC, except very rarely some minor cut-offs, and these usually have been solved by reestablishing the Bluetooth connection. However, the main gripe I have had with these is that whenever I'm on a 2.4GHz WiFi the internet speed decrease to almost zero or unusable depending of WiFi signal strength. And this happens every freaking time. Only way to get usable internet connection with LDAC on is either use cellular data or 5GHz WiFi connection. Very bad design defect IMO, and I would like to hear whether anyone with the M2 has experienced the same problem.
It's an inherent problem with the Bluetooth standard. There isn't anything they could do in a codec to affect radio interference.Sony's engineers certainly had all the knowledge about the technical requirements and limitations when they designed the LDAC and yet they couldn't come out with anything better than this.
