I wrote to Sonnet today to seek some clarity on the best way to connect via the Matrix X-SPIDF 2 converter. They emailed back as follows:
"I2S is probably not the way to go as it is optimized for our Hermes so as a result it will not work properly in conjunction with the Matrix. Still I2S is not a standard so I advise you to go for the AES/EBU"
I did have a brief chance to run the Morpheus via coax today on a simple converter, but then it broke. Matrix should be here in a day or so.
In the meantime, right now I have to say, I'm really enjoying the Morpheus, but I'm hoping the transition from USB to AES/EBU will render its technical aspects - especially layering and imaging - more precise. I also hope the dynamics could be a bit more punchy. The timbre is very agreeable. It balances a smooth tonality that does not feel rolled off. Having said that, on USB, the comparison between the Hugo 2 and the Morpheus is not night and day. Yes, the Hugo 2 lacks body in the lower mids, the treble is a bit glaring, and it doesn't have as smooth a presentation as the Morpheus. But in terms of resolution, I am not yet in a position to say the Morpheus is significantly ahead. The Sparkos Aries amp enables me to quickly A/B between sources, and the differences are not radical. It's also true that the Hugo 2 has a more forward/aggressive presentation, which might give a more hyper-contrasted sense of detail. The Morpheus is more subtle but no less resolving.
I will see how it pans out with the AES/EBU, and also see how it unfolds with more hours put in it. It's undoubtedly a great DAC but whether it's "the one" remains to be seen. I certainly feel it has the potential.
