Below is the config of Metrum and I assume the same would be true for Sonnet.Hi, how are you connecting the Pi2AES to the Morpheus? If you can point me in the right direction on where you got the custom cables, it'll be much appreciated!
I'm still waitingfor my Pi2AES. Also, what LPS did you settle on? I'm looking at the iFi iPower Elite 24v. Says the noise floor is under 1uV!
And below is config of Pi2AES
D-W-B-G-M pins on the Pi2AES are Serial Data - Word Clock - Bit Clock - Ground - Master Clock
Now if you get some jumper cable and connect the pins from Pi2AES to a RJ45 BOARD like below
as shown
https://imgur.com/a/J5nYsBw
You will hear music
I hope it helps.
