redmaw
- Apr 11, 2010
Hi,
I have this issue where if I play a multi channel audio file the channels are not mixed correctly for a 2.0 setup when I use the optical (SPDIF) output. It sounds like I am just getting the FR and FL channels for the most part. I double checked the settings in the media player and everything I could think of was set correctly and if I switch to USB connection everything sounds fine. Anyone know what else I could check that could be causing the problem?
For those curious as to why this is a problem, my better DAC does not have USB input and my other DAC/AMP needs to be retired soon
