ursdiego
- Oct 25, 2010
Hi there!
I ordered a Audio-gd Ref 9 DAC. This has two outputs and I am a bit confused, not knowing which one I should use, and also a bit worried about potentially damaging my pre-amplifier.
I own a DNM 3B Primus pre-amp (specs here for the 3C Primus that are the same as for mine: http://www.dnm.co.uk/previouspreamps.html )
It has 5pin-DIN-Line-Inputs. And it sais the following about the input:
Line sensitivity: 150 mV
Line Input impedance: 5.6-47 k-Ohm
Now, on the DAC there seem to be two connections:
- +15V1 / -15V1
- +33V / -33V
Which one should I use…….?
more about it here:
http://www.audio-gd.com/Pro/dac/RE9/RE9EN.htm
I usually connect Chinch-devices like CD-Players or tuners with a simple Chinch – DIN – cable… and I did not know that there are differences in Voltage between connections…
I wrote about that questions to Kingwa, but I did not actually understand his reply:
“The DAC output stage power supply is +/-33V.
The output level is 2.5VRMS.
Do you want to lower the output level?”
I am confused… hopefully one of you technically skilled hifiers can help me!
[size=12pt]Best regards![/size]
- +15V1 / -15V1
- +33V / -33V
more about it here:
