Fitz
- Nov 12, 2005
30 seconds? I get about 15 seconds to full temp on my 936, and I run mine hot.
Originally Posted by hilikus /img/forum/go_quote.gif Yes I plan to get some Cardas Quad-eutectic http://www.welbornelabs.com/solder.htm Also where do you get your nylon covering? |
Originally Posted by Fitz /img/forum/go_quote.gif 30 seconds? I get about 15 seconds to full temp on my 936, and I run mine hot. |
It is only rated at 15 watts right? Well hmmm...show me waht chapter in my physics bok that directly relates watts to HEAT! That iron gets to 800 Watts my friend! Unless you are trying to solder with molten iron than i would have to say it gets plenty hot. You see how small that tip looks? It is even smaller in person! And all that heat is concentrated on that little tiny tip. |
Originally Posted by picklgreen /img/forum/go_quote.gif I was being facetious tomb but thanks for that great phyics lesson! The point was dont let the meager 15watt rating fool you. It will get plenty hot to melt solder for SMD or intricate pin soldering. |
Originally Posted by smegger /img/forum/go_quote.gif are these cold heat irons and good? all i really will be using it for is a grado rewire and a few interconnects? if no could someone recommend a good budget iron in the uk? |
