JuicyBruce
- Aug 31, 2011
Hi all,
I bought the following to replace the terminals on my chris_himself cable but i'm damned if I will be able to make it work.
The circled "plugs" are only about 2mm deep and the cuts you can see are about 1mm. I have bare silver wire and inserting into these holes does not seem like an option. I had originally though they may be crimps but unfortunately not.
If anyone is familiar with this type of connecter or has experience making strong solder joints with close to zero real-estate please let me know.
