Walie
- Mar 21, 2005
Thinking of getting a tube amp for my sr-225s. I'm thinking of commissioning someone to build me either a SOHA or millet max. Which one would be best?
Originally Posted by Walie /img/forum/go_quote.gif Thinking of getting a tube amp for my sr-225s. I'm thinking of commissioning someone to build me either a SOHA or millet max. Which one would be best? |
Originally Posted by headphonejunkie /img/forum/go_quote.gif I just wanted to tell ya that I have a SOHA and a 225 and they make a great combo. Gain is not that big of a problem with a 100 ohm resistor on its output. Which is what I have . I think the SOHA gives you more options with tube rolling and when the JISBOS bds become a reality I believe the SOHA will beat the millett. That is my opinion on this subject.I have previously owned a millett with diamond buffer and I still believe the SOHA will be better with its JISBOS bds.Also, the JISBOS is going to be a class A output too which is what should put it ahead of the millett. Of course some opinions may vary. |
Originally Posted by tomb /img/forum/go_quote.gif HJ, the Millett MAX has a deeper Class A output than will ever be possible with the Jisbos. You can put 100ma or more through the transistors with those extruded heat sinks on the MAX. Even Amb's latest Jisbos board shows the output transistors hanging off the edge with little stamped metal heat sinks. That's probably about 30ma max configuration. . |
Originally Posted by headphonejunkie /img/forum/go_quote.gif I just wanted to tell ya that I have a SOHA and a 225 and they make a great combo. Gain is not that big of a problem with a 100 ohm resistor on its output. |
