tomb
Member of the Trade: Beezar.com
- Mar 1, 2006
Evaluating test points without the pot in the circuit is a long-standing issue: it doesn't work. Same for the opamp: you cannot get intelligible measurements. If everything measures OK with the pot and the opamp in the circuit, then you're fine.
Originally Posted by gates_2 /img/forum/go_quote.gif so.. problem not solved... With the pot out, i get 70 plate, and then like 51, 56 on the 2 +40 check points..... No matter how much i turn the trimpot either way, neither of these values change The second I connect the pot.... I get plate voltage at +60 and both +40 voltages, or If I turn the pot all the way one way, I get plate voltage at one +40 and a lower voltage at the other.... Ended up breaking a RK27 pot trying to desolder it from my pimeta to try on the soha... GAH any ideas... With teh pot wiper all the way one way, I get a short between input left and ground... Confused..... |
