"In an analog system, the signal is continuous, but in a PCM digital system, the amplitude of the signal out of the digital system is limited to one of a set of fixed values or numbers. This process is called quantization. Each coded value is a discrete step... if a signal is quantized without using dither, there will be quantization distortion related to the original input signal... In order to prevent this, the signal is "dithered", a process that mathematically removes the harmonics or other highly undesirable distortions entirely, and that replaces it with a constant, fixed noise level."
S.P. Lip****z, J. Vanderkooy and R.A. Wannamaker. 1991.
Minimally-audible noise shaping. J. Audio Eng. Soc. 39, 836-852. and J. Vanderkooy and S.P. Lip****z. 1987. Dither in digital audio. J. Audio Eng. Soc. 35, 966-975
Vanderkooy - Present Research Activities: A study of the linearizing effect of dither in quantized data systems, especially digital audio, has resulted in a number of papers which show that properly dithered systems are totally free of distortion and noise modulation at all signal levels.
Try this link too:
Phys. Rev. E 61 (2000): Robert A. Wannamaker, Stanley P. Lip****z, and John Vanderkooy - Stochastic resonance as dithering
So you know dithering theory is incorrect do you, well why don't you write your own thesis and disprove the theory of dithering which has been a routine proceedure in digital audio for more than 15 years.
Ignorance is bad enough but then to argue and broadcast your ignorance just makes you an idiot! Now why don't you supply a reference to a paper in as reputable a publication as the AES journal which proves the dithering theory incorrect.
