jkorten
- May 1, 2012
Unfortunately no. I recommend you stick with the M8 for Linux. It works great on Windows, Linux driver is problematic. Seller would not take back the unit (ebay beware). But it really isn't the seller's problem, it is the Linux driver's problem. If it works under Windows - but not under Linux then the product isn't to blame.
Mine is on ebay now for those of you who use Windows. It sounds marvelous on the Windows OS.
