Small-ish channel imbalances in high-end 2ch systems are a vexing problem
Aug 27, 2010 at 3:58 AM Thread Starter Post #1 of 7
By a "small-ish" imbalance, I mean that the left or right channel is stronger by about (say) 0.3 to 1.5 decibels, and that this results in a shift of the sonic image's center. Once the imbalance gets to 2.0 dB or more, it's pretty egregious to the point that most people can't help but notice it; usually this means you've got a serious setup or component issue. However, smaller cumulative imbalances can arise even with properly functioning, well setup gear.
This is an issue that's driven me nuts for years, and I believe it's quite common in high end setups. Assuming your gear is all within specs, a channel imbalance is most likely caused by:
1) Your phono cartridge - Many high end models are spec'd to only within 1.0dB of perfect L/R balance. Some allow as high as 1.5dB, and the flagship level usually offers 0.5dB, which is still quite audible. I'm ignoring the effects of turntable setup here, which I'll assume has been done properly.
2) Your room setup. Acoustic asymmetries can cause the image to appear off-center, and the effect can easily be perceived as a 0.75dB (or so) imbalance - though the exact amount is going to be frequency-dependent, which is somewhat complicating, whatever happens in the critical midrange region is what you're most likely to perceive.
Electronics and speakers/headphones are a less likely cause, though still a possibility. I've seen an old pair of tube monoblocks, otherwise perfectly functioning, with a 1.2dB imbalance (it wasn't the tubes); they still sounded great. Headphone systems driven from a digital source are free of the two primary causes, though in my experience high end headphones seem less precisely balanced than speakers (for whatever reason), so an imbalance can still be an issue in these systems. Ironically I think the more handmade nature of high-end cans doesn't do them any favors here.
In my 2ch speaker system, an imbalance of 0.5dB is quite noticeable. It corresponds to a perceived shift of roughly 3-5 inches laterally across the soundstage (for reference, my speakers are 7-8 feet apart and I sit 8 feet back). So, a singer that should appear dead-center over my TT spindle now resides over a side of the platter. At that, it's annoying. An imbalance of 1dB is much worse; yet, that's not terribly uncommon even with all properly functioning gear (a cartridge can contribute that alone).
I'm not aware of any good high end solutions, and that surprises me (yes, I know the digital/PC guys can compensate whatever they like in the digital domain). Well, other than perpetually swapping gear to chase the right mix, which admittedly many of us are addicted to. Surely this must also drive other audiophiles up the wall? Yet it's hardly ever discussed.
Solutions? The problem is that as pursuers of sonic bliss, we're paranoid about introducing components into the signal chain that might degrade sound quality; even for such a worthy cause as perfect channel balance. The solutions I've tried include:
1) Get a preamp with a balance pot; these days it's a rare feature. My Rogue Audio Hera surprisingly has one - an Alps Blue type. It can be switched in/out of the Hera's circuit, and this is fortuitous, because it audibly degrades sound quality. Mercifully the the main volume control is a nice (motorized) stepped attenuator. In this case, I'd rather deal with a small imbalance.
2) Swap various L/R interconnects in an attempt to cancel out imbalances. This only works if you've got an even number of roughly equal imbalanced components (including the room), and (sometimes) if you're willing to live with swapped L/R channels. It's unlikely you'll achieve perfect balance with this technique, but sometimes it can reduce the problem "just enough".
3) Build a simple resistor box or cable that attenuates one channel by a small amount. It's a bit of a pain to go "DIY" (I for one have no desire to get into amp building), but this is as easy as projects come in DIY-land. First, you calculate the resistance value needed for a desired attenuation in dB; if the desired attenuation is small then you can get away without a shunt resistor (note that the calculation depends on the input impedance of the component it's feeding into). I'm not very handy so I used a simple plastic box with 2 pairs of RCA connectors. This requires use of an extra set of interconnects, however in my listening, the balance it achieves far outweighs any degrading effects of the extra components. Since I chose to place the box before the phono stage (this can be risky because of the chance to pick up noise), I also added a cartridge loading resistor; in this way I could select a value not offered by my phono stage (I've settled on 230 ohms with my Koetsu cartridge for now, the closest settings on the phono stage were 100 and 1000). In the past week, I've been MUCH happier listening with this box - I can tolerate record crackles/pops, but even a small imbalance just drives me nuts! This is just one of those issues that I have a LOW tolerance for. I can highly recommend the DIY route as a solution, if you've got a small system imbalance that's been eating away at your soul :)
Ideally, I would want a discrete-step balance control in my preamp (a stepped attenuator balance control). At a minimum it should offer +/- 1.5dB of balance compensation, in 0.5dB increments. This would allow for a balance within 0.25dB - which is vanishingly small - and with a minimum of sonic degradation. An imbalance of more than 1.5dB is getting into "something's wrong that needs fixing" territory, so I think that this range and granularity combination would be effective for most systems. I just can't believe this isn't an ubiquitous feature in quality preamps (along with a mono button/switch, which at least does get some love from manufacturers).
Has anyone else here obsessed over small-ish imbalances like me?
Aug 27, 2010 at 8:57 AM Post #2 of 7
I agree with you on the need for the ability to make very small incremental volume changes in one channel to address proper balance.  When I had my Levinson Ref. 32 linestage in my system, I could make changes as small as .1 db by remote control.   I could quite easily hear a change of .2 db up or down in one channel (change in channel balance) even though it is pretty hard to hear a 1.0 db change in overall volume.  My current linestage (Emotive Audio Epifania, allows for .5 db incremental changes by remote and that change is very easily heard.
I would NOT consider a linestage that does not offer either balance control, or for that matter, does not allow for a change in volume and balance by remote control.  The proper balance actually changes from recording to recording and when switching between digital and vinyl as sources.  The ideal volume level also sits within a narrow range that is best found by sitting in the listening chair and making changes by remote.  I have used linestages with stepped attenuators with  2.0 db steps for volume control; inevitably, the preferred volume setting is somewhere between the steps.
Sep 1, 2010 at 3:39 PM Post #3 of 7
I would take a rusty spoon to your left ear.
Sep 1, 2010 at 5:11 PM Post #5 of 7
DACT makes a 24-step*0.25db per step stepped balance control. total range +/-3db
I have no idea why its more expensive than their normal volume controls, but it is available off the shelf :)
The goldpoint mini-V custom should be able to be built as a balance control too, and probably at a better price. (famous last words...)
Sep 2, 2010 at 7:06 PM Post #6 of 7
How about adjusting the balance on your preamp to the left or right?
Or am I missing something?
Sep 3, 2010 at 4:00 PM Post #7 of 7
I've got a local friend into 2ch that's even more annoyed by channel imbalances than I am. A 0.2dB imbalance would be quite noticeable for him too, though it's probably getting near my threshhold. I also used to hate the 2-4dB steps stepped attenuator, but I've been just fine with it on the Hera preamp - fortunately it has 5 gain settings and the steps are more moderate.
I've noticed I was much more fixated on finding the "optimal" volume while using headphones, since it's a narrow window where you just start to get a sense of good dynamics and impact, but before you're at ear-fatiguing levels. With speakers, this seems like a much larger window and thus is more forgiving. Though, this is up to personal preference. Rogue told me that they've switched from a SA to a TKD pot in the Hera II, because so many customers were demanding a smooth volume control. I do believe the SA will sound better if you can deal with it.
I bet we'd both be surprised how well the brain will adapt and compensate for a deficiency on one side (to a certain degree, at least)! Then you're back to square 1 with imbalances...
That looks PERFECT. I wish it had been built into my preamp - I'd never have to build another stupid resistor box again, no extra set of I/Cs, etc. Hmm, wonder how much custom work that would be - the knob & switch are already there, and the Alps balance pot is worthless...
Because the Alps balance pot causes a noticeable degradation in sound quality. When it's switched into the circuit, it's the only potentiometer in the signal chain.
