Vaiki
- Nov 24, 2012
Does anyone use a small flat type case for their IEMs? I was thinking of using a thicker cigarette tin/case. I need something that would fit in my pocket and most of the soft circular cases are kind of big, and will flatten in pockets.
Edit:~
Found some...
Pelican 0945
Pelican 0910
Mainly any SD Memory card cases can be modded with some foam lining inside , most of them are waterproof as well!
A nice alternative would be to use wooden cigar boxes to store your IEMs in at home if you're looking for something classy.
Edit:~
Found some...
Pelican 0945
Pelican 0910
