Singxer SA-1 / Balanced Amplifier Fully Discrete Class A - beyond THX 888 ?!
Apr 22, 2021 at 2:47 PM Post #527 of 2,667
What dac are you using? Many people will argue DACs matter, and I’m starting to believe it myself, I use a RME ADI 2 DAC and I’ve heard people describe it as cold...and this may be true considering that’s it’s designed for accuracy. I’m now considering one of the denefrips dacs to find out for myself.
I had a RME ADI 2 DAC but had to return it, it was like broken glass in my ears. Shame cos it was an awesome bit of kit.
Apr 22, 2021 at 4:35 PM Post #528 of 2,667
So I'm finding the sound is changing. Sadly not for the better. it's getting so bright and fatiguing. The low end has kinda reduced as well. Hoping this is just a phase until it settles down, but right now I'm not enjoying it at all.
I wouldn't worry about it now. Looking back at the thread, it looks like your SA-1 is only about a week old at this point. Some amps take 300+ hours to fully burn in. I woke up today and my amp sounded worse and it had definitely entered the pits of burn-in hell, and will probably not completely re-emerge for some time. Just the normal burn-in process as I've experienced in the past with other components and gear. I use mine normally during the day and loop pink noise overnight, and will continue to do so for at least 2 weeks. I'm postponing any further sound quality judgements until the process completes.
Apr 22, 2021 at 4:45 PM Post #529 of 2,667
Ah so I'm not alone. Yeah it's definitely in that zone right now. I'm not to worried at this point.
Apr 22, 2021 at 5:04 PM Post #530 of 2,667
This forum makes a great support group LOL. What type of pink noise do you use? Silly question probably. I’ve left mine just playing music on low-medium volume - is that acceptable generally speaking?
Apr 22, 2021 at 5:06 PM Post #531 of 2,667
My order from two weeks ago just shipped from Apos. Just fyi for those waiting on theirs.
Apr 22, 2021 at 5:51 PM Post #532 of 2,667
Units arrived at Europe suppliers today and already sold out. Mine ships tomorrow.
Apr 22, 2021 at 6:46 PM Post #533 of 2,667
Haven’t listened to music in maybe a week but I did today and I must say this amp is definitely a step up from the a90 and two steps up from the 789/887...also I was messing around with it and noticed that my Arya’s became more alive when I maxed out the amps volume and adjusted my dacs volume to listening level, just had a more full and engaging feel to them. I don’t know if that’s misuse but I think I’ll be listening this way from now on.
Apr 22, 2021 at 6:55 PM Post #534 of 2,667
Theory has it that it's better to have the DAC at 100% volumen, 100% detail, then adjust sound level with the pre-amp or headphone amp. If you do it the other way around you are adjusting volume on the digital field, which means lower the volume lowering audio resolution...
Then again for use with a remote, a dac with remote is very cheap, a preamp or headphone amp with remote is very expensive, so, for that use digital volume is the only thing possible.
Tehn again, if the dac provides a ton of power, and the amp has to work in low load and sounds thin or anemic, then well, no other option either... No golden rules i guess.
Apr 22, 2021 at 7:05 PM Post #535 of 2,667
Yea it’s def something I never done before, but it sounded really good for some reason
Apr 22, 2021 at 7:42 PM Post #536 of 2,667
Nothing wrong with that, it depends on which device has the more transparent volume control. You're essentially using it as a power amplifier, which I wish someone would make for headphones!
Apr 22, 2021 at 7:50 PM Post #537 of 2,667
I really think any of the current delta sigma chip dacs sound like broken glass really in any busy part of the track. R2R or multibit or chord is the only viable option apparently to leave behind the digital world of broken glass. But for less than rme you can get ARES2. Much less features, but potentially much sweeter and smoother and less sharp sound.
Apr 22, 2021 at 8:15 PM Post #538 of 2,667
I think you might be right. I'm going to give this X16 a chance to run in, it's sounding very good, but does start to sound like a wall of sound when things get busy in a song, then it's a bit fatiguing. The Ares2 is probably where I'll end up I recon.
Apr 22, 2021 at 8:45 PM Post #540 of 2,667
Also wanted to give MQA a go. I was really close to getting the Ares2 but I wanted to see what MQA had to offer. Turns out absolutely nothing, what a swizz.
I’m in the same boat re: MQA. Don’t find a huge huge difference but there is usually a slightly higher volume level and a little more depth. Varies song to song.
I ended up going with the X26 Pro because I like the clinical nature for electronic music and gaming. I think an R2R will be in my future though, I’d really love to hear and A/B one.
