That one, not only is not 34mm, it is 32mm, but also is a downgrade from the original, since it is extremely ugly, pretty much as tall as the stock one. The molted surface is very low quality, the rolled mechanizing on the front gives this 70's aesthetics, and last but not least, the white triangle has no haptic feedback, unlike the original with the spheric mechanization.I already told you, mate, this 34mm one works! https://www.aliexpress.com/item/32813579033.html
Although 34mm outer diameter, it has 32mm at the back, so it snugly fits into the recess if you don't push it all the way. I have it, I've installed it and it works perfectly fine:
Internet forums...
