Don Quichotte
...so, how can I get rid of the DC offset of my T-amp? Can I install a pair of electrolytics on its outputs? Does it have some output caps of its own that could be replaced? And how can I access the lower side of the PCB? ( I opened it up and the PCB is attached to the bottom case by a pair of black little plastic sticks; I can see there are three caps in there, but I don't know what is their role and I cannot reach them)
If it's possible then it's a simple mod I guess, so I thought I should post here and not in the diy forum.
For those horrified by the idea of mating the mighty K1000 with the t-amp, of course it's only a temporary solution, but (unfortunately) it's a necessary one in my case.
Thanks in advance.
Thanks in advance.
