M1dN1ght
I recently picked up a He1000se refurbished directly from Hifiman for $1350, and I really think this is endgame for me; At least for the foreseeable future. The only problem is that with my current signal chain (Hifiman EF500 and Shiit Lyr+) I find that they just aren't as warm or musical as I would like them. I know this is a common problem people have with the HEKse, but I find them sibilant more often than I'd like which really takes me out of the music.
I've spent countless hours at this point looking for a solution that doesn't break the bank, as I'm 18 and can't responsibly spend much more than 1k on a signal chain for these. This is especially challenging considering I've been trying to find a used DAC with quality single ended outputs below $600 that will tame the treble, bring out a good bit of the potential of the HEKse, and has a good USB implementation as I plan on mostly listening through USB from my laptop. I'm currently considering a few options, namely the iFi Neo iDSD 2, SMSL DO200 Pro, Geshelli Labs J2S, Shiit Bifrost 2, and even the Black Ice Audio Glass Fx in which case I would sell my Lyr+ and only use the headphone out of the Glass Fx.
Currently I'm leaning toward the iFi Neo iDSD 2, because I keep hearing it described as smooth, full, and slightly warm. Also the USB implementation and filters look nice. I have heard the that the HE1000se paired with the iFi Pro iCan Signature sounds chalky though, so I am a bit worried that that characteristic will also come out with the iDSD 2 since they are both iFi products.
I'm open to any suggestions and will consider selling my entire signal chain and starting from the ground up. Just figured I would ask Head-Fi before making any decisions, because for some reason there aren't any places in Nashville which carry headphone gear.
