[1] Not at all. Why don't you see if you can find such loops, fade-outs, etc. and pass the test? After all, your threshold is the same as mine, right?
Why is it that when you get involved in a dispute, you feel the way to win that dispute is to misrepresent pretty much everything; what has been stated by the posters with whom you're in dispute, the evidence presented and and even science itself? And, if that's not bad enough, you then insult those with whom you're in dispute by stating they are ignoring the evidence and the science, which you've either misrepresented or are doing yourself!! It derails the thread, it's hypocrisy, it's mis-information, it serves no purpose and benefits no one except you and your ego and potentially the audiophile myth peddlers, which makes what you are doing contrary to one of the main reasons this sub-forum exists in the first place!
Bigshot has not stated his threshold is the same as yours, that is a complete misrepresentation! He stated that training cannot improve hearing thresholds, a statement with which I agree and why I am defending him. He did NOT state that his threshold is the same as yours and if he did, I would not be defending him. Here's another example:
[1] When we want to declare something to be transparent, then it needs to be so for all content and all people. In any listening tests, we hugely shrink that to a few tracks and a few people. Of course we still like to the results to apply to all people and all content. So what we do is that we give every chance to artifacts to be audible. That way, we have a better chance of testing other people with or without training having higher acuity than our sample listeners. And to allow other content to be revealing. ... This is not theory.
[2] Then one day we had one of our partner companies ...
1. This assertion is self contradictory and yes, absolutely it IS theory!
We do indeed typically "give every chance to artefacts to be audible". We rig the test; we use very high quality equipment, in laboratory conditions with exceptionally low noise floors, using subjects with trained hearing or hearing trained specifically for the artefact being investigated, who are focused exclusively on detecting that specific artefact, at higher or much higher than normal levels and we use test signals specifically designed and/or manipulated to maximise the effect of that artefact. As we can't test every single human being, creating the most favourable conditions for the humans we can test is the most logical/practical method of discovering a limit of human ability which we can be confident will not be exceeded by any other humans we haven't tested, under normal conditions. It's useful to know such limits, when designing equipment and products for example, but these limits are of course JUST THEORY! We cannot know whether we've rigged the test so favourably that the limit demonstrated by the test in fact exceeds the ability of EVERY human being under ANY reasonable definition of "normal conditions"! In fact, there is a considerable amount of well accepted, reliable evidence which indicates that indeed, this is extremely likely to be the case in a number of controlled audio tests. In other words, some/many of the limits demonstrated during scientific testing should be viewed as limits which under normal conditions will probably never even be approached by anyone and all but possibly a miniscule fraction of outliers will never get anywhere even vaguely in the same ball park as such a limit!
2. Yes, anyone who's been involved in the industry in some capacity has some surprising experiences and anecdotes to tell. I have many, but then there are two sides to this coin. For example, in this thread we've discussed tests which demonstrated that the generally accepted 20kHz upper limit of human hearing is insufficient, that some individuals, under some extreme test conditions have detected 23kHz or 24kHz signals. On the other side of the coin though: In about 1973 (I believe), a BBC engineer, during a system test, discovered that the BBC had inadvertently been broadcasting a reasonably high level 19kHz signal over their programmes for a period of about 4 years, without anyone noticing! Baring in mind that at the time, apart from the BBC there was only one other available TV channel in the UK, so everyone who watched TV in the UK over those 4 years invariably watched the BBC at least some of the time and, that the BBC has an unmatched history of encouraging (and actually receiving) consumer feedback/comments. Obviously, we're still not talking about every single person on the planet but a sample size of about 50-60 million people, in effect tested continuously for about 4 years, is significant! It's significant enough to state with some confidence that the accepted 20kHz limit is more than enough, although it doesn't completely exclude the possibility that there might (or might not!) be an individual or possibly even several individuals in the world for whom that limit might not be quite enough. This brings us to those of us who actually create the commercial content to which everyone is listening. We have a finite amount of time to complete our part of the commercial creative process, should we divert some of that limited time away from the frequency range which is audible by all, to a frequency range which is probably not audible to even a single person on the planet? Unfortunately, sometimes we have to do exactly that, to the potential detriment of the product, because there are people who visually check the >20kHz content of high sample rate material.
BTW, these last two points are for the benefit of others! Despite the fact that the above basics facts should be known, accepted and self-evident to anyone with professional experience (and even to some/many without professional experience), as it would appear to conflict with his personal agenda I'm sure amirm will either just ignore, misrepresent or find some excuse to dismiss it.
G
