I changed the ear pads on the Samsung Galaxy Buds3 Pro from medium to large, I had no problems during the replacement. There is no damage (tears), as you can see in the photo.
The procedure for replacing the ear pad took 30 seconds. I turned the ear pad inside out and took it by the base, then pulled it up with a little effort. The mount has grooves and a snap (similar to a suction cup with grooves), so you need to make a little effort to remove or put on the ear pad, it is important to get into the grooves. The material of the ear pads is silicone, if I'm not mistaken.
For me, the large size of the ear pads is too big, and the medium is too small, I left the large with it, the passive sound cancellation is better (most likely, there will be a problem finding the right size of ear pads for me, if Samsung does not make another size of ear pads between medium and large).
While the Buds 3 Pro are charging, I'm currently listening to the Sony WF-1000XM5 and they sound just as great!
I'm liking mine so far. I think the ANC is only ok - strangely, I found the Buds 2 Pro to be better in this respect. However, I do think the Buds 3 Pro sound better and are now competition for other earbuds, particularly following access to the best of SSC following the firmware upgrade to the S24U last week. My favourite buds, to date, have been the Denon Perl Pros (the Dirac processing and the sound customisation do, in my experience, positively influence SQ).
I am having one weird and random issue with the Buds 3 Pro. Every so often, a track advances without reason. To advance a track normally needs a squeeze on the earbud stem (touch is reserved for volume control). Annoying and random - sometimes they play normally for ages, at others this behaviour happens fairly frequently. Anyone else experienced this issue?
