nicholars
- Aug 28, 2011
removed
I have the ath-m50. Is the 1540 a significant step up? Is it worth upgrading to at triple the price of the m50?
LCD2 and HE500 I am sure are probably better but also need serious amping, cost a lot more and are not as light / comfortable... So yes a porsche 918 is obviously better than a porsche 911... but it also costs a lot more... LCD2 + an amp is about TRIPLE the price of 1540... At £300 I paid for the Shures I do not think there is anything better as an all rounder. Denon Dxxxx, Momentums, HE400 and HD650 are all very good in particular ways but do not have as good all round sound that works well with every genre.
For example the mids are slightly too recessed / thin at times on 1540, but then on the HE400 and D2000 they are extremely recessed... The problems on the 1540 are minor compared to others. HD650 has better mids but no sub bass at all, Momentums sound good but have miniscule soundstage, HE400 and D2000 have horrible sibilant treble unless heavily EQ to the point they have basically no treble left (HE400).
For example the "no EQ mentality"...
SRH 1540 are all round very good... The treble peak can be annoying sometimes and mid can sound too far back compared to the treble peak.... "no EQ mentality" would be "right ok I am selling the headphones and spending 2-3x the amount to fix that".... OR You could just have one flat EQ and one with a small reduction at 10-12khz.... This will give you zero / almost zero reduction in sound quality... Simply reducing the volume of that frequency slightly... The sound is then fine with no treble peak on tracks where it is annoying (already bright / sibilant recordings) and you can use flat EQ for others... BUT... "I must not EQ because it is against my principles, so I will buy a new amp and new headphones" Don't understand it.
Well, whether something is worth it or not is very subjective. Yes the 1540s are a step up in quality but i wouldnt say they sound 3 times as good. I thought the 1540s sounded very good but i also thought there were some cheaper models that were comparable in sound so for their normal retail price i think they are a little overpriced personally. But then again i'm about to buy a pair of noble k10s which are crazy expensive but worth it to get what i want.
What headphone would be comparabale in sound but less expensive as an example?
You can't say a headphones has weak mids(1540) then call it an all-rounder lol an all-rounder should be a headphone that does everything well. The 1540 does not do well with vocal tracks. It does not have the body and natural flow with vocals.
The NAD VISO is what I would call an all round headphone. It does everything very good. Better than the Shure in most areas.
Anyway. Just suck it up, I don't rate your headphones so just deal with it really. No amount of arguing is going to make them any better.
Again, take a deep breath..relax! I don't like EQ..be a man and accept it. Loads of people don't either.
