nicholars
- Aug 28, 2011
I might be bit of Shure 1540 basher; I thought they had a flaw considering the price, overpowering bass and U shaped frequency that may sound impressive on first listen but would get tiresome after 15 mins. Mind you other qualities were good like comfort, imaging and separation, hf sparkle..
Expensive "studio" headphones as these are referred to, (in my opinion) should strive for balanced-neutral signature and not try to follow a bass heavy signature.
After returning the Shures, my current headphones are the Focal Spirit Professional - flat response and bass sounds like it should - no mid bass bloat and tight bottomless sub, comfort is not amazing but its quite good (gets much better over time), and they sound much more balanced and natural than the Shures to me, essentially what I expect the original recording to sound like and not EQ'd for XXXtra bass - for half the price!
I really wanted to like the Shures, the comfort is great and they sound like open back headphones, but I couldn't live with their frequency curve.
With the Xonar STX they sounded "U" shaped and a bit irritating at higher volumes... With the D1050 dac they sound neutral to me and higher volumes do not sound irritating at all... very smooth treble and no grain at all with the D1050 using async USB and a QED USB cable... much bigger difference than I expected from a DAC/AMP... I got it on demo and bought it the next day because it sounds so much better than the STX with these headphones... if you are looking at the "harman target resonse curve" they are almost exactly in line with that.... If you consider neutral as a straight line then they are not neutral, but to me a flat response sounds thin, the D1050 makes these headphones sound very good, I definitely recommend the D1050 and 1540 combo!
