Hi
I've just bought the wireless SE215s, which are a pair of SE215 earpieces plus the wireless cable which is available separately.
I'd really like to know:
1) How much quality loss there is using the 535s with the cable
2) Whether using the 535s (which are triple drivers) results in a significant reduction in battery life over the 215s.
I get more than 11 hours out of the cable with the 215s despite shure only rating them for 8 hours. I'm tempted to get a set of red 535s but if it's going to ruin the battery life it won't be worth it.
If anyone has the 535s and can test them with the cable it would be much appreciated. Make sure to run them all the way down because the voice prompts indicating battery status are not accurate!
