wiz561
- Jan 26, 2010
I have a set of Shure SE535's with the Effect Audio Pearl upgrade cable. The IEM's are about 18 months old and the cable is about a year old. It seems like when moving around or rotating the cable, the sound will click in and out...almost like it's a loose connection.
Doing some research, it looks like the SE535's have/had(?) a problem with the connector not making a great connection and causing the problem. When I put the stock cable back on, it seems like things are good. I then put the Effect cable back on, and it had the problem again. Put the stock back on, and it seems good again.
Now I will say that I take extremely good care of these cables and SE535's. I don't work out with them, don't do stuff with them, just sit at my desk with them. I originally had the SE530's which developed the infamous cable split right after the warranty expired. I paid $250-ish for an after warranty replacement for the se535's, and now that the warranty is almost up with the se535's, I'm a little concerned that this is a problem with the IEM and not the cable.
I was wondering if anybody has had a similar problem with the Effect Cable, or if anybody had any suggestions. Thanks in advanced.
