neutral
- Jun 11, 2010
I've bought a pair of SE215 headphones a few years ago (around 2012) and I've been happy about their build and sound quality. Their cable seems tough, as well as their monitors, even though the cable started to become green (I have the clear model) after some time (especially since after one time I used them in the gym) but from what I gathered from the internet it seems to be an issue with this model that doesn't affect sound quality (I actually don't know if this may be related to the problem below).
However, from a few months until now, they have been making some rattling noises every time I move the cable. I've since cleaned the headphones and started from the jack since I first thought that was where the problem was. Later I cleaned the connectors with alcohol, q-tips and a tooth pick to remove some dirt[0] and found out that it was actually that that was causing the rattling sound and for a little while (maybe a day) I could ear music without a problem. But eventually the next day or so my left monitor restarted to make those noises and even after I cleaned it up again doesn't seem to have made a difference.
My question here is: do you believe the problem is in the monitor themselves or the cable?
Because the original cable is a bit expensive and I would like to be sure before I order a new one. Or do you believe the problem actually relies on the monitor? Do you have experienced any problems like these with your SE215? What's your opinion?
One small note: the monitors and the cable seem to be a little loose (not that they don't fit correctly; they do and attach very well to one another but I'm able to tilt them a bit and I'm not sure if they're like that from the beginning or not).
I also believe to have taken good care of the headphones. I can't remember of a time were the cable was pulled or the monitors took any type of strong fall.
Thank you for your help.
[0]: seemed to me to be some kind of rubber
