moseboy
- May 27, 2007
Yeah, they had a pouch too. I have both and prefer the clamshell, but I don't think the nano 4G would fit in it. But I could be wrong.
Originally Posted by msuben /img/forum/go_quote.gif Thanks for the replies and advice. Just ordered the Shure SE530 and looking forward to getting them! |
Originally Posted by robm321 /img/forum/go_quote.gif just from a practical standpoint, I would go for the E530s. I personally would not spend that kind of money on an IEM if I weren't going to use an amp. |
Originally Posted by msuben /img/forum/go_quote.gif Is there enough room to fit an Ipod nano (4th generation) in the included Shure case? |
Originally Posted by limin /img/forum/go_quote.gif Hi, I can fit a 2g nano, which is almost the exact same size as the 4g nano so it should be fine EDIT: actually it only fits if you don't plug it in, if there is anything plugged in, it will not fit... |
Originally Posted by moseboy /img/forum/go_quote.gif Yeah, they had a pouch too. I have both and prefer the clamshell, but I don't think the nano 4G would fit in it. But I could be wrong. |
Originally Posted by jinx20001 /img/forum/go_quote.gif good choice picking the se530, i also find them fitting for such a broad range of music, even classical manages to shine, but only at higher volumes, at low volumes the high range is certainly recessed, but has anybody noticed that if you crank them the high range really crashes away, very clear and not rolled. |
Originally Posted by jinx20001 /img/forum/go_quote.gif in fact, i think the se530 are some of the most EQ'able IEM's available, and if you really are a high range person then EQ'ing 8khz and upwards really brings out some shine. |
Originally Posted by jinx20001 /img/forum/go_quote.gif which ones had a pouch, ive owned a 2006 model and now a 2008 model and both had the oval clam case. |
