Boringz
- Jul 12, 2006
Stereo sells them, tried them at the store.Same here in Singapore. I ordered mine from Amazon Japan. Delivered in 5 days.
I thought Stereo only had them on pre-order for early November (see their website). I want to get a second pair for my son. Will check it out. Thanks
That’s totally fair—I don’t think I’ve ever used the TW1 buttons for anything other than turning them on and off, and even then, I’ve always used my thumb to support the back of the earpiece so my pointer finger doesn’t dislodge it. And like you said, the tactile feedback is pretty poor. I guess I still prefer it a bit to touch controls like those found on the Airpods Pro and Sony WF-1000XM3 just because those cause a very unpleasant thud-like sound in whatever ear you‘re tapping on.I'm really disappointed by that. And quite curious if that's just me, or why noone else brought that up before.
So I've read through all 24 pages and most of the reviews to me were at least on the positive side.
I got my TW1 yesterday and started using it today, to be honest I'm really disappointed with the sound quality. Basically not much of a difference compared to any cheap IE Earphones available. Eg. Sennheiser CX300S.
Now don't get me wrong, I'm not promoting sennheiser cause I just sold my MTW2 75th Anniversary Edition at a loss of $79 when I barely used it for 3 times (Battery issues & alot more but I cba explaining in this post).
Is it just me or the TW1 sound quality is horrible ? The app is even worst though, no folder sorting and 1 of my favourite song was missing only in the app lmao.
Could it also be that I got a faulty unit ? This can't be the quality of Shure. The difference between wired and TW1 is literally heaven & earth.
Thinking of upgrading 535 to 846 and stay wired
Connected using Poco F2 Pro (if that matters)
That’s surprising, since I understand the Poco F2 Pro has the Aptx codec.
I have not tested the Tw1 with my SE535, but the sound quality using the SE846 with iPhone 11 Pro Max is great.
However, I did have problems getting a good ear canal seal. The TW1 rubber straps are quite rigid and tended to pull out my spinfit double flanges (breaking the seal resulting in tinny sq). I switched to large Comply professional P-series, which have 50% longer tips. That solved the seal problem for me.
PS: I haven’t used the Shure app except for the initial setup. I play music through Tidal.
