Should the HD 800 factory cable be replaced?
Oct 2, 2015 at 6:22 PM Post #31 of 46
Sennophile
I cannot recommend enough using a balanced cable with the HD800.  I've opted for the Sennheiser CH800.  The difference was dramatic and astounding.
Oct 2, 2015 at 10:43 PM Post #32 of 46
jodgey4
What amps? Balanced shouldn't make a difference.
Oct 3, 2015 at 2:44 PM Post #34 of 46
jodgey4
Using the SE output and balanced are almost always going to yield different results, if the amp is meant for balanced output, it'll sound better through balanced. That's a design point of your amp, nothing to do with just getting a balanced cable :).
Nov 6, 2015 at 3:35 PM Post #35 of 46
lupulalb
Hello guys ! HD 800 headphones are dedicated amplifier HDVD 800! What are these cables do not know 1)> https://customcans.co.uk/s/s/index.php/cables/sennheiser-cables/hd800-high-balancedxlr.html 2)> http: //www.linum .dk / product-overview / 3)> http://www.effectaudio.com/upgrade-cables/headphone-upgrade-cable.html 4)> http://www.c3audio.com/store/p11/Sennheiser_HD_800_Headphone_Cable_- -_UPOCC.html! Had someone experienced in their use especially this combo? multumsc advance for your attention and answers!Hello guys ! HD 800 headphones are dedicated amplifier HDVD 800! What are these cables do not know 1)> https://customcans.co.uk/s/s/index.php/cables/sennheiser-cables/hd800-high-balancedxlr.html 2)> http: //www.linum .dk / product-overview / 3)> http://www.effectaudio.com/upgrade-cables/headphone-upgrade-cable.html 4)> http://www.c3audio.com/store/p11/Sennheiser_HD_800_Headphone_Cable_- -_UPOCC.html! Had someone experienced in their use especially this combo? multumsc advance for your attention and answers!
Nov 25, 2016 at 11:43 AM Post #37 of 46
Pinoyjaa
It would be nice if we could objectively measure the difference. Sometimes the placebo effect is quite evident given the advertising hype. In the end, of course, what matters most is how satisfied we are with the sound we are getting!
Feb 4, 2017 at 5:28 PM Post #39 of 46
eeagle
FL, Space Coast
Mar 30, 2017 at 2:13 PM Post #41 of 46
Bowers0199
The stock cable can be brought from around £180 and £250 depending on where you can find it, I Tried a few upgrades The best being from Norne audio , But it cost around £700 ,, Was it worth it .. I think so . But then again is paying £2000 for an amp And £100s for for interconnects ,, Again I believe So , If its What you're into Why not invest , Its all relevant and you judge the value from the hours of use you get out of These things , Example ..Over A thousand pounds for a season Ticket for a top premier league club ,, I know where my money would go
Mar 30, 2017 at 2:17 PM Post #42 of 46
Bowers0199
There are several suppliers of good quality audio cables , Norne Audio , Moon audio , If you're in Europe Forza audio works . I have brought cables from them all and they all do great quality cables , Do your research then try one and judge for yourself
Mar 31, 2017 at 12:45 AM Post #44 of 46
Odor trader
I have been nothing but thrilled with the sound from my HD 800's, but I recently came across a Six Moons review that flat-out ridicules the stock cable. Quoth the reviewer: "Stock cables aren't up to par. They must be replaced or any true discussion on performance is invalid."
Really?! Were these headphones actually *held back* this whole time? That's a frightening thought.
Is there any truth to this? To be honest, I've ran some searches, and I'm not even sure what that type of cable is called, the kind that are interchangeable like that. Where do I find them? Which are best for the model in question?
Advice appreciated; thanks for reading.
I think a better cable could help minimally help with audio. But what does make a difference is XLR, but that's a different beast in itself. Updating 1/4 or 3.5 won't yield as much.
Only reason you should upgrade in that case is if it's for comfort/look/weight. Otherwise high overpriced cables is probably more than not just snake oil.
Mar 31, 2017 at 11:02 PM Post #45 of 46
jodgey4
XLR vs SE generally shouldn't make a difference on comparable well designed amps, unless you're going over long cable lengths.
