K271 Guy
- Feb 22, 2004
Is that coil adjustable side to side so you can change the timing? You can tweak those things a bit with different octanes
"so far what I learned is to forget the Airhead" |
Originally posted by Steve999 I returned the 271s and kept the SR60s and HD280s! I think the 271s are the worst of the lot! Check out the Headroom AKG 271 Frequency Response graph! Ick! Go figure! Just my two cents. |
Originally posted by commando Don't worry about the graph, use your ears. I have 280s and 271s and I much prefer the 271s - the 280s get barely any use in comparison. To my ears, the 271 has much, much better bass and is quite smooth and easy to listen to. The 280 is more analyical, has better treble (too much IMHO), and feck all bass. I can't stand to listen to the 280 for very long, but I can listen to the 271 for hours. |
